Ive been trying to compile my mpg files that have the audio sound converted to 4800.
When i have tried the dvd files in dvd lab, it says i cant do the compile as the files display in sizes thats not for dvds.
I tried tmp dvd author and the same happened what can i do?
What are the screen sizes then?? You can make a "xdvd" if you use dvdpatcher and patch the size to a valid dvd size but it may not work on all dvd players then.
they are svcd size
I want dont want to make a xdvd i want it so the movie will play on all playesr -
Assuming the width is 480 (SVCD) and you want the finished item to play on all dvd players, then the only option you have is to re-encode the mpegs. If you re-encode to a width of 352 you will then have a valid dvd size.
SVCD to DVD reencoding guides:
https://www.videohelp.com/guides?tools=&madeby=&formatconversionselect=SVCD+to+DVD&ossel...or+List+Guides -
is their any easy programs that i can load my mpgs into and it converts them? or what is best?
File Sizes
By rhodellf in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2009, 13:51 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
HD TV and DVD sizes
By elDuck in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2009, 09:16 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
