Hi!
Having trouble flashing my nec1300a burner. Have seen that other people had the same problem and that your supposed to remove nero 6 which I did but when flashing with firmware from herrie all I get is a error:drive not responding correctly.
Is there a way to unlock the drive somehow?
Should I remove the player and then put it pack -- might that do the trick?
Mike
How did you go about flashing your firmware? What OS are you running? Did you follow the instructions and flash it in DOS? I flashed my drive by booting to a Windows 98 CD-ROM on my XP system and running the flash utility from a floppy disc - had no problems whatsoever and my drive is still going strong over 2 months later.
-Free -
Hi freestyler!
You wrote:
I have Windows XP, run it from ms-dos boot disk, booted in dos and when i run the firmware I got a error message: drive not respinding...Originally Posted by freestyler
I created my bootdisk in Xp by formatting a floppy to ms-dos
Flashing went wrong with my DVP5992/37
By chiquito3 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd Apr 2010, 20:56 -
Native Linux firmware flashing
By disturbed1 in forum LinuxReplies: 0Last Post: 7th Mar 2009, 22:09 -
Flashing Arrows To Emphasise
By Squid_uk in forum EditingReplies: 10Last Post: 13th Mar 2008, 23:17 -
Tutorial for Flashing your Xbox 360
By steve42069 in forum ComputerReplies: 0Last Post: 31st Oct 2007, 22:55 -
VirtualDub - Flashing lines on playback
By terrypin in forum Newbie / General discussionsReplies: 9Last Post: 28th Aug 2007, 05:27
