1. I have a divx with ac3 5ch audio. Can TMPGEnc and toolame fix so the output have 5.1 audio? I don't think so..
2.I have a divx with ac3 2ch audio. Is there any way to get 5.1 audio from that?
Do i need to rip out the audio to a wav with virtual dub and fix the audio file in some other prog and then convert it with the video in TMPGEnc (in both my cases)?
Or only convert the video in TMPGEnc and how do i get the audio in after the conversion??
There must be someone who knows which prog to use and in which order to use them so i can burn it as an DVD ????
I intend to burn it as an DVD and play it in my standalone dvd player with my DTS 5.1 amplifier.
The new BESWEET can do the job for you. Rip the audio withd VD and load into BESWEET and convert it to AC3 5.1.
Good luck -
1. Convert the video separate, rip the audio with virtualdub and fix it with ac3fix or beslice and after that join the new video and the ac3(or some authoring tools can import separate streams).
2.You can't get 5.1 from stereo. It is enough to convert to ac3 stereo. -
Originally Posted by Draven
Ok thanks man. It saves me some time....
Just so i got it right..
If i have a divx with 5ch ac3. I should rip it out with virtualdub fix it with ac3fix and then add it again in TMPGEnc and i can also plug in toolame ??
Even if i save it as an wav in virtual dub i don't fuc... something up with the 5ch? They say all this in the guide so ??
And one other thing do i get the dolby didgital not the prologic icon on my amplifier ,as i get when i play the original dvd ??
5.1 audio question - is a single .wav file true 5.1 DTS?
By jazzsander in forum AudioReplies: 5Last Post: 18th Apr 2012, 21:00 -
How can I reduce a 1080p video file to 720p and keep dts audio?
By jeff552004 in forum Newbie / General discussionsReplies: 6Last Post: 16th Oct 2011, 01:24 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 14:49 -
How to stretch a DTS audio file from 23.976 to 25.000 fps?
By lorix in forum AudioReplies: 3Last Post: 10th Nov 2008, 13:55 -
Clicks in DTS audio stream in MKV file
By MisterB42 in forum AudioReplies: 0Last Post: 23rd Aug 2007, 17:25
