Hello, I was wondering what progam to use to burn a dvd .img file and how I cant seem to figure this out. I have nero 6 alcohol120% instant copy and roxio ez cd dvd any help would be great Thanks!!
Results 1 to 10 of 10
You can use ISOBuster to unpack it (search google to find it). You can then burn it with whatever software you want to use. ISOBuster is free for individual use, and will unpack just about any type of disk image. Very useful when you download alot of video from the internet.
Impossible to see the future is. The Dark Side clouds everything... -
Try DVD Decrypter 3.1.5.0, this allows u to burn dvd .img.
Bless,
ukRevRend -
I agree. I have played with a few and this is the best and easiest wayOriginally Posted by ukrevrend
DVD Decrypter is great Free software. For DVD-5s it is a MUST in my opinion.
-Free -
Yep - the easiest way to use DVDDecrypter is to naviagate to the .img file and right click on it. You should get an option 'Copy image file with DVD Decrypter' or something similiar.
HTH
Kevlar -
Decrypter.
I'm not sure why anyone would use anything else. Decrypter has never failed me. (knock on wood)
How to obtain a tiny sample of an *.img file from a huge *.img file
By lousk in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 09:03 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Burning .IMG Files to DVD
By niteghost in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2008, 19:13 -
.img file on my dvd player
By godmode99 in forum DVD RippingReplies: 4Last Post: 23rd May 2008, 18:31 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
