I've successfully used Pinnacle Expression to author DVDs of my home movies. When I do this, the program calculates the compression (video bitrate) to fill the DVD. If the DVD is 'over', it tells you so and won't let you burn. Even if Expression predicts the DVD only has 1 minute left on it, the actual burned DVD has 600-800 Meg available! Expression 'over predicts' the size of the authored DVD every time! I hate this wasted space. Any way to correct this? Pinnacle was no help (surprise!).
Thanks,
Dave
All I can say is Pinnacle Expression did a bad job in predicting DVD size, therefore waste lot of space.
It should NOT be surprising that Pinnacle provides no help. Did anyone get help from Pinnacle before ? Go to their forum and you will see most questions are un-answered by Pinnacle personels.ktnwin - PATIENCE
Need new non-AC3Filter AC3 decoder from Expression Encoder
By CasanovaFly in forum AudioReplies: 17Last Post: 30th Jun 2011, 16:41 -
Pinnacle 12 DVD Menu question
By thejigsawman in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2011, 12:39 -
need alternative program for microsoft expression encoder
By fixme in forum ProgrammingReplies: 0Last Post: 29th Nov 2010, 16:01 -
Converting mkv to dvd size question?
By riky in forum Video ConversionReplies: 3Last Post: 10th Jan 2010, 07:04 -
Question how to increase subtitle size on DVD
By jimdagys in forum SubtitleReplies: 20Last Post: 14th Sep 2008, 11:07
