I would like to know which is the best solution to get the best quality when I´m capturing from my Video Tape with my captured card Pinnacle moviebox USB. Have I to capture an AVI and when I have it ,to convert to a MPEG2 with CCE (for example) or I will get a better work if I capture directly in MPEG2 with Pinnacle Studio 8 ?Thank you.
First I doubt that you can get a decent quality capture with USB device.
Second Pinnacle Studio 8 only pretends to capture in MPEG-2, it actually capture in AVI (DV if you get Firewire) and then converts to MPEG-2 in the background (which takes forever).
Third, best quality to one may not mean best quality to another. I personally stay away from USB capture device.ktnwin - PATIENCE -
Too late for him (if your correct). But, I would like to see your source for this statement:Originally Posted by ktnwin
Pinnacle PCI or USB 700
By SerbianBoss in forum Capturing and VCRReplies: 18Last Post: 30th Mar 2011, 23:12 -
Pinnacle 500 USB
By Dem Pyros in forum Capturing and VCRReplies: 20Last Post: 26th Aug 2010, 13:18 -
Pinnacle usb 500
By kortmann in forum Capturing and VCRReplies: 2Last Post: 26th Aug 2010, 00:50 -
Pinnacle 500-USB?
By beene in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2008, 04:13 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 04:20
