Hello, after a reinstall i decided to install my videocapturing progs. Before the reinstall everything worked perfectly (using premiere 6.0).
Now:
When i try to install 6.5 it goes good but then when i open it it closes down after loading a couple of settings (in which you see the countdowntimer).
I dont get any errors.
In 6.0 i can't control my camera. I get the ever popular error "the dv device is unavailable for device control". I searched everywhere but nowhere did someone post the solution (only the problem).
Now i don't know what to do
Anyone can help ?
I'm using the updated WinXP with directx 8.1. I got a JVC DVcamera and a standard firewire card wich is recognized by windows.
"Against All Odds"
i dont know how to fix the problem your having but i think you can
go around it.
if your problem is importing from your camera to the computer, you can import the video using other software, and than edit with premier.
i think you can import using moviemaker (it comes with windows xp)
you can even edit it with moviemaker, add things to it if you want to.
just an idea, i hope it helps.HELL AINT A BAD PLACE TO BE -
I'd suggest checking the Adobe forums and knowledgebase. I have had no problems with 6.0 or 6.5 under Windows ME or 6.5 under XP Pro so I can't be much help. I had some errors with one of the installs, but so far it hasn't caused any problems running. I capture from a Sony TRV-30 on a firewire port.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
My 2 problems with Adobe Premiere
By IT learner in forum EditingReplies: 2Last Post: 16th Sep 2011, 08:46 -
Quality problems on Adobe Premiere Elements 9
By inimitable in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2011, 05:56 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 01:56 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
