Changing a region 3 DVD (ntsc) to region free (ntsc)?
I know you can change your regions to region free with DVD Decrypter.
I just need to know if you can do that with your computer's dvd drive even though it's set to region one? Thanks for the Info!![]()
Results 1 to 10 of 10
There's a piece of software you can also try out called "DVD Region Free" that can do what you're asking and works quite well. There is a trial version available on their web site.
http://www.dvdidle.com/ -
I guess what I ment was in order to rip the dvd does my drive have to be the same region as the dvd I'm ripping? Thanks!
Rip the movie with DVD Decrypter.
If you do your ripping in FILE mode or ISO mode then it will be region free. When ripping the region code crap and all copy protection crap will be removed.
If the DVD is a single layer disc simply rip in ISO READ mode then BURN that IMAGE file to a DVD-R using ISO WRITE mode.
If the movie is dual layer then best to rip in FILE mode and then use something like DVD2ONE or DVDShrink etc. to make it the size you need for a DVD-R
Thanks for the info. I'm fixing to rip a couple of region 3 Godzilla films. Make them region free.
Originally Posted by bipartite
No need with single layer discs to use anything else.
The DVD-R copies will be region free
Now if only the new MechaGodzilla would come out on HK DVD already!
GODZILLA X MECHGODZILLA UPDATE
Life is SWEET
Haven't thought about this movie in a while so I just came back from HK FLIX and guess what?
The HK region 3 NTSC DVD of this title is NOW available !!!
Japanese Language in 5.1 DD and 5.1 DTS with English subtitles. This is also Widescreen but if it is like the other HK Godzilla DVD discs then it is only 4:3 Widescreen (not 16x9 enhanced) but considering the last 3 Godzilla films have been unreleased in the USA I am not going to complain!
Best of all ... $14.95 plus shipping
Life is SWEET
- John "FulciLives" Coleman
P.S.
Here is a direct link:
http://www.hkflix.com/xq/asp/filmID.528913/qx/details.htm"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 09:28 -
Does making a dvd player region free also allow PAL to display on NTSC?
By dizmack in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2010, 19:50 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 18:48 -
Region Free/ Ntsc PAL Compatible
By veryconfused in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Nov 2009, 18:53
