Ok i wanna convert my movies that r in .avi format to .mpg format so i can watch them on my apex dvd player. What program should i use and what would b the settings so i can fit it onto a 700mb disk. Or is there a way to watch .avi's on a apex dvd player?
apex model ad-1110w
Try reading some of the guides on this site. Start with the convert section, you should find what you need to get started there. Then you will need to author and burn, there are guides for that too. If you have problems, feel frre to come back and ask specific questions, detailing what you have done so far and waht has gone wrong.
Hope this helps. -
I just wanna convert avi(691mb) to regular mpg file, only have a cd burner not a dvd burner. Tried with TMPGEnc various ways and also with NeroVison Express but when converted with TMPGEnc it was 2 gig and nero well its to big to fit on a 700mb disk.How do i convert to mpg and retain a near same file size?
Again: read the guides under HOW-TO/Convert. The size of your AVI has no correspondance to the size it will be when encoded to mpeg. The mpeg size is determined by the movies length in time, and what bit rate you use when encoding to mpeg.
Use a bit rate calculator (found under Tools) to find what bit rate to use.
A VCD (700 MB CD-R) can hold about 80 minutes, SVCD less - from 60 down to 30 min (but with a better picture quality).
If you have a movie longer than these figures, you have to split the movie over several CDs.
/Mats
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 18th May 2010, 23:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 03:19 -
Vegas compare/contrast with other prog.
By ineedhelp123 in forum Newbie / General discussionsReplies: 7Last Post: 29th May 2008, 12:40 -
recording live - prog like snapz?
By marinebc11 in forum MacReplies: 1Last Post: 25th Apr 2008, 08:30 -
What prog. encodes several videos without burning?
By Shapeup1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 18:16
