help my pioneer a05 has locked in region 1 any way of sorting as need to ripp region 2 as a rule. me forgot to check how many times i had changed region. thanks all.
Results 1 to 14 of 14
There are many tools to make your drive region free to avoid this problem entirely......
you can find them here in the tools section:
https://www.videohelp.com/tools#Region free tools -
It isn't very smart to keep changing the region on your DVDR drive. You only get 5 changes each time the drive is unlocked, but you can only send back and pay for it to be unlocked 4 times. (25 region changes in total).
The only real way is to send it to the manufacturer and have it unlocked.
Try using AnyDVD for the moment as it should do software based region changes. -
i have tried the very dodgey firmware upgrade to 1.33 and luckily it seems to be ok, but still will not read region 2 on power dvd,tried a few region hacks but to no avail.rcp2 seems to be the problem with newer drives. looks like posting it back to mr pioneer. oh i wish i had checked.
just downloaded any dvd and hey presto finally one that works,if only for the free trial, thanks dudes.
pixel any idea how much pio charge to unlock drive, ps thanks for advice on any dvd, works a treat if a bit slow to pick up drive. one more question i have a spare dvd drive that is new, is it possible to run two dvd drives without any problems. could i use it to ripp to h/drive and the pio to burn ?
locking your drive has NOTHING to do with ripping.
no matter what region your dvd rom is locked on, you can still rip a dvd
of whatever region you want.
you just cant PLAY it in your dvd.
i had an LG drive that locked out on me, but it still could rip a dvd
no matter what the dvd region was.
i just couldnt watch the dvd using the dvd rom.
rip to the HD and you can even watch it on your computer.HELL AINT A BAD PLACE TO BE -
Does this also apply to RCE ? Because my region 1 locked DVD wont read RCE region 2 discs - DVD Decrypter throws a wobbly when attempting to open the DVD.Originally Posted by Heavensent
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I do not have a clue but I'm guessing it would probably cost about £30 (about $40), not including postage. Anyway, I wouldn't bother about it too much, as long as you use AnyDVD or something like it you can still rip DVD's. (If you do get it unlocked you will probably want another drive a few months down the line anyway.) Only bother about getting it unlocked if you plan to resell it.Originally Posted by benson
There should be nothing wrong with using another DVD drive to rip (I have always done that so as to not burn out my writer prematurely due to the amount of stopping and starting the disc I do during ripping and normal use) to the hard drive and using the pio for burning.
@VCDHunter I don't know of that problem, but AnyDVD should solve it, or try another tool like Smartripper. -
thanks for all replys,i am now using a dvd rom to ripp and the pio to burn with,on my travels i downloaded dvd decrypter this software seems to work even if i use the pio, when it checks the region codeing it says the code is wrong for the drive but says it will force region and gets on with it,try it it does work, but as you say it is possibly better to use a dvd rom to ripp with anyway as they do tend to zipp about a bit.so im now using dvd decrypter, dvd 2 one to take out the crap, and nero 5.10.35 to burn with. so far phonebooth looks a treat. no doubt i will be back here one day for more help,thanks all.
VCDHunter wrote :
i cant remember if i had a problem with RCE,Does this also apply to RCE ? Because my region 1 locked DVD wont read RCE region 2 discs - DVD Decrypter throws a wobbly when attempting to open the DVD.
but i THINK it should work.
i just cant find a reason it will not.
RCE just wont let you PLAY the movie if your dvd is not locked
on the right region.
but the dvd rom can understand ANY dvd structure
(as long as its standart)
so in theory, you shouldnt have a problem riping in to your hard drive.
but i cant say for sure if it will work.
maybe you can try to rip with smart reaper, it sometimes works better.HELL AINT A BAD PLACE TO BE -
I often Rip Region 2 DVD's w/ my region 1 drive. DVD Decrypter has to use Brute Force DeCSS instead of the faster IO Key exchange but it usually works. However one time I coudln't do anything, no vulenerable sectors.
DVD Decrypter shows -
I/O Error !
SCSI Status 0x02
Interpretation : Check Condition
CDB: AD 00 00 00 00 00 00 02 08 04 C0 00
Interpretation : Read DVD Structure
Sense Area : 70 00 05 00 00 00 00 0A 00 00 00 00 6F 04 00 00 00 00
Interpretation: Media Region Code Is Mismatched to Logical Unit Region
Smart Ripper Shows -
Some Files Are Still Locked
Neither will rip this DVD
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Dvd player locked due to bad region hack :-S
By A$$hole in forum Newbie / General discussionsReplies: 6Last Post: 12th Jan 2009, 10:17 -
Pioneer DVD DV-393 Progessive Scan Locked - Problem Solved
By kbm in forum DVD RippingReplies: 2Last Post: 27th May 2007, 18:52 -
Pioneer dvd - dv 393 progressive scan locked in
By kbm in forum DVD RippingReplies: 7Last Post: 27th May 2007, 01:39
