Just replaced my aging and noisy TV Wonder with AvertTV Studio. I used the same universal drivers that I used for TV-Wonder, so I can capture at any resolution in VDub. TV-Wonder did not have S-Video working under Win2K though, but this card has it working, sort of. I am getting these irritating vertical lines on the screen, they are highly visible. They are not seen in composite input mode, maybe because it is less sharp in general. Anyone found the cause for it? Is it the 4-to-7 pin converter that comes with AverTV?
BTW, the card is at CompUSA for $70 with a $40 (!) rebate. That means a brand new card for $30. It comes with a remote and its own audio in, and I found that makes the sound much better. The picture is probably worse than a brand new TV Wonder, but I could not find a new one that is not the Value Edition. I got the stereo version years ago, probably the last batch![]()
Digitizer
If it ain't digital, it ain't real -
I'm sorry, your video is interlaced.
TMPGEnc can de-interlace video files for you under expert settings. Read up more at http://www.100fps.com . -
Hmm, I have been doing video caps for years, I know interlacing when I see it. Besides, I said vertical, not horizontal lines.I'm sorry, your video is interlaced.
Sounds like interference lines.
You could try to eliminate the svideo/rca adapter as a cause if you had a straight svideo source in.
I have an older avermedia tv98 card which has been very faithfull until I moved my computer setup to a different room. My svideo connection is now causing a similar problem so I use the rca input instead. I suspect the closeness of a new 32 inch TV with side speakers which are very close to the svideo cable running from my cable box. I may eventually track the source down when I have time. I tried switching 3 different svideo cables so I know it's not that.
p.s.
In my case capturing from some digital cable tv stations seems to magnify the problem more than others. When I use the rca input the problem is gone.There's not much to do but then I can't do much anyway.
Vertical lines in SD camcorder video ?
By Umen Pich in forum EditingReplies: 8Last Post: 21st Dec 2011, 20:25 -
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum Capturing and VCRReplies: 0Last Post: 11th Dec 2011, 16:54 -
Vertical dark lines on captured video
By jsr184 in forum Capturing and VCRReplies: 6Last Post: 29th Jan 2009, 21:31 -
Vertical Lines from Video Camera
By solarblast in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2008, 22:30 -
vertical lines in 2.5
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 23rd Jun 2007, 15:53
