Hi all
I'm quite new to DVD authoring and I'm having a few problems loading Video and audio files into DVD Maestro. I have ripped a dvd and have a VOB file in 2 parts: VTS_1_0.VOB, and VTS_1_1.VOB. Analyzing these 2 vobs I see that the movie has been split into 2 parts. When I demux VTS_1_0.VOB into its video and audio elements these load into DVD Maestro without any problems, however when I demux VTS_1_1.VOB, and try to load the video and audio I get a "Media Detection Error" from DVD Maestro and niether the video or audio will load! I presume that maybe this is because the second VOB file has no header information and Maestro does'nt recognise the file.
How can I load both parts of the VOB file? Do I need to join them together first and then demux the one file and then load it into Maestro? If I do what is the best way to join the files?
Any help greatly appreciated
Dan Hawkes
You might want to skip VTS_1_0 because it is probably a menu.
Have you viewed it ?
It also may be at a different aspect ratio which might irritate
Maestro as it probably wants everything to be the same.
Try VTS_1_1 by itself -
FOO is right. The VTS_01_0.VOB is usually the main menu, so you can't join the VOBs. But for future reference, if you want to join VOBs do a search for VobMerge. It's a great little program
"Can You Dig It!"
Free program to join vob files with dts audio
By shans in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2013, 06:50 -
Join and Convert VOB FIles
By solai_4 in forum Video ConversionReplies: 3Last Post: 18th Mar 2010, 04:27 -
How to join vob files -CORRECTLY!
By mcfcguvnors in forum EditingReplies: 18Last Post: 17th Jul 2009, 08:38 -
how do i join VOB files
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 4th Oct 2007, 08:10 -
How to join 2 DVD VOB files??
By hilario in forum EditingReplies: 5Last Post: 15th May 2007, 17:53
