  1. It this possoble? If it is, how so? See below:
    Can I create DVD-Video discs using my PC DVD+R/+RW drive?
    Yes. To create DVD-Video discs using a PC DVD+RW drive requires the proper premastering software that can encode video and audio into DVD formats. Furthermore, you need software that can generate a DVD-Video disc image file that conforms to the DVD-Video specification to allow for playback on DVD-Video players. Most tools will handle all of these steps in the so called "authoring process", so you will be able to feed your source material into the application (either already available on your computer, for example from an Internet download, or captured trough a video board), customize the video and the look of the menu screens, and then create a DVD-Video disc using your DVD+R/+RW drive. Fore more information about creating DVDs and Video-CDs, converting video into DVD format and most other DVD auhtoring related questions, refer to this excellent web site: www.vcdhelp.com.
  2. If I've ever seen an odd post this it it!
  3. I just cut and pasted it from another forum. I was asking a question about the post, when I said see below..
  4. The answer to your first question is 'yes'. for the second question see the "How To" section over on the left. <-
  5. Which How To Section?
  6. Sorry, found it. Thanks.
