I started a VCD2.0 project, added a MPEG1 file, enabled PBC and selected 'equidistant chapters' and burned the CD just fine.
But when I play the VCD in my DVD player, there is no PBC, no menu, nothing. It just starts to play.
I know my player supports PBC because when I create a still picture slideshow using Ulead PictureShow software, it indeed shows the menu page(s) and responds to the remote control buttons.
Out of curiosity, I popped in the VCD in the computer and sure enough, the SEGMENT folder is blank. Shouldnt PBC-enabled VCD have the play (segment) items in this folder?
Actually, even when I am authoring the VCD in VCDEasy and go to the ISO9660 tab, the SEGMENT folder is empty even after I add the chapter entry-points.
What am I doing wrong?
So I can move to the chapters using the numeric buttons on my remote?Originally Posted by sterno
Also, how do double-digit numbers work on my remote? i.e. if I want to jump to chapter 10, would I press 1 and then 0 quickly? Why wont this get interpreted as 2 separate keypresses?
How can I create a menu containing the chapters/entrypoints as selections? I looked at the guide on vcdeasy.org but couldnt figure it out. Is there a step-by-step guide somewhere?
If you set the PBC to assign the numbers to the entrypoints, yes.Originally Posted by vikasa
Depends on your player. I think my old player had an "enter" button on the remote so it would be 1-0-ENTER. I think my current player has an extra button to increment the 10s. I think some just use a timeout, you have to hit both numbers within a certain amount of time.Originally Posted by vikasa
I haven't looked at that guide, but really all you need to do is create a VCD MPEG or a VCD still image with the picture you want as a menu and set up the Interactivity tab so that the numbers go where you want.Originally Posted by vikasaA man without a woman is like a statue without pigeons.
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
Trouble with OE
By alegator in forum ComputerReplies: 4Last Post: 6th Feb 2009, 15:52 -
PS/2 Trouble
By gooberguy in forum ComputerReplies: 22Last Post: 19th Jun 2008, 19:08 -
eac3to trouble...
By kulmagen in forum DVD RippingReplies: 7Last Post: 17th Feb 2008, 06:51 -
Having Trouble With DVDFAB
By Dr_Shakalu in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2007, 16:56
