I didn't know where to post this, so I put it here. I just built a system and it is working fine with one exception. I have a 2 disc VCD and when the first disc is finished and I insert the second disc and try to play from the "player" (Windows Media Player or Power DVD) the system (Windows XP) crashes and the system reboots. If I play the second disc from explorer it works fine. The second disc doesn't have to be from the same movie. This happens using any "2nd" disc. But it only happens if I open the drive and then play the video. If I don't open the drive (and it happens with any combination of the two drives installed), but just try to replay the discs in the drives, everything works fine. It only crashes when I play a video, open the drive, and try to play again. And only if I try to play from the player application, but not if I play from explorer.
The obvoius answer is to play from explorer but I'm looking fo a better one. Does anyone have any ideas? I've installed all the new drivers and XP patches. Thanks in advance for any help.
does it reboot by it self.if so,since you said you just built your computer i would check the bios update and see if it says anything about you video card and windows xp.Originally Posted by saspgmr
can a PAL disc work fine in a SECAM system ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 05:55 -
Lg dvd player/system not playing dvds
By maddog83 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Feb 2012, 21:14 -
Using Ulead VideoStudio 11.5 plus - system crashes during rendoring
By hvs08 in forum Authoring (DVD)Replies: 6Last Post: 3rd Mar 2010, 00:28 -
Trouble playing DVD-Rs on home system
By wysiwyg20 in forum Video ConversionReplies: 1Last Post: 14th Oct 2007, 09:27 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 04:40
