Hi
I bought some karaoke VCD's but as usual, not every song is to my liking so I would like to
(a) compile a VCD containing only those songs I like and
(b) copy the songs I like onto a CD so that I can play them on any CD player, including the Discman.
But being a complete newbie, I do not have a clue of how to do it. I'm using Nero 5.5 that is bundled with the CD Writer.
Thanks![]()
If you want to make Audio CD out of Video CD:
1) Get VirtualDub
2) Write down the track numbers of the songs you want to get.
Repeat for every song:
a) Go to File -> Open Video File
b) Browse your cd-rom, go to MPEGAV folder, choose the file with name like Avseq02.dat (your track number instead of "02")
c) When the opening process is finished, go to File -> Save as WAV
d) Choose output audio file destanation and choose save.
Note: You can Copy the content of VideoCD to your harddrive in order for VirtualDub to work faster spliting audio. Do not forget to choose your copied files as sources.
Movieconvertor Studio (V1.6) Hangs but works when selected ....
By phase52001 in forum MacReplies: 4Last Post: 8th May 2012, 21:25 -
How do you blur selected frames in AVIsynth?
By Nagashi in forum EditingReplies: 4Last Post: 9th Jan 2011, 19:30 -
Selected input is not BD format
By Mark AL in forum Authoring (Blu-ray)Replies: 8Last Post: 5th Oct 2010, 02:30 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
DVD to AVI with selected subtitle language
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2008, 17:45
