hi i ripped a sports telecast from tv and since i had problem using files bigger than 800mb , i split them to 3 files but my problem is that the program is putting them in the wrong order makes file 3, 2 , 1 , is it enough when i drag the files in the right order at the vts menu ?
thx
AnonymousGuest
It should be i did a disc with 8 eps once and the order was fine but i put every ep in a seperate vts.
Greatings,
Yf -
In a given VTS movies will be played from top to bottom.
from an ordering point of viewCode:
- VTS -sport1.mpg -sport2.mpg -sport3.mpg -sport4.mpg -sport5.mpg is the same as - VTS -sport1.mpg - VTS -sport2.mpg - VTS -sport3.mpg - VTS -sport4.mpg - VTS -sport5.mpgSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Determining correct order in AVISynth Script?
By Killer3737 in forum Newbie / General discussionsReplies: 6Last Post: 22nd May 2011, 11:28 -
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 13:41 -
JPegs don't play in correct order on DVD player
By NichoPhoto in forum Newbie / General discussionsReplies: 12Last Post: 3rd Feb 2010, 07:11 -
What's the right way to fix a field order problem?
By brassplyer in forum EditingReplies: 13Last Post: 28th Dec 2009, 10:03 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 09:19
