Results 1 to 10 of 10
    Camelot, U.K.
    Is it possible to convert an XSVCD to plain old SVCD? If so, how do I go about doing that? AVICODEC tells me this XSVCD is:
    File : 558 MB (0.0 B), duration 0:00:00, type MPG, 1 audio stream(s), quality 88 %
    Video : 0.0 B, 15000 Kbps, 29.970 fps, res. 480*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
    Audio : 0.0 B, 192 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    I have tried de-multiplexing, and then trying to convert the video to 2000 kpbs and then multiplexing... seperating the audio to a .WAV and then reencoding...nothing seems to work or give me something I can burn to a CD to watch on my DVD player. Help!!!
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I can't spot anything "X" about that. All withing SVCD specs as far as I can see. If it's multiplexed as SVCD, and you author it properly (=using VCDEasy imho) you should end up with a SVCD well within specs.
    /Mats
    Camelot, U.K.
    I think the Video: 15000 kbps makes it slightly more than is acceptable to my DVD player and also does not fall within the guidelines of SVCD which I believe tops-out at 2500 kbps. Not an expert here so maybe I'm missing something...I tried with VCDeasy AND Nero 6 Ultra to burn the XSVCD without processing and my DVD player will NOT recognize it at all. Mind you, I have a relatively new DVD player that can play not only DVDs but VCDs and SVCDs as well. It WILL NOT play this in the least.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Ah - that's one I didn't see. I read 1500 kbps, not 15000. Most DVD players can't read faster than the max SVCD data rate (if even that) from a CD, so if your player has problems with 15000 kbps, it's not that strange! Let me see, what's the duration then; a 6 minutes clip?
    /Mats
    Camelot, U.K.
    Mats:
    I'm really in over my head here on this one. I browse the newbie forum here frequently because I'm kinda new to this. I have been having very good luck with converting PAL to NTSC and have been successful with AVIs and just about everything thats been thrown at me...however, I have not been able to do anything with this XSVCD. I was hoping there was a program that would cut that 15000 fbps down to a more manageable rate...I guess you don't know of anything like that???
    Anyway, I still would like to get this where I can watch it...
  6. Chances are, it's not 15000kb/s. Either you read it wrong, or theres something wrong with the prog. 15,000 is twice that of DVD quality, and doesn't coincide with SVCD, or xSVCD paticulars.
    Camelot, U.K.
    Actually, I have four (4) of these...all classified as X(S)VCD and all have the same Video: 15000 fbps...I did not read it wrong...now possibly AVICODEC is confused...I am just relaying what I'm getting out of that.
    Again, as I mentioned earlier, I am a newbie. Assuming that AVICODEC is interpreting it correctly, is there any applications that can cut this figure down to a more managable rate? TMPGenc gets about half way through and "locks up". Don't think TMPGenc can digest this bitrate...any other programs out there that anyone knows of???
  8. How big are the files?
    Camelot, U.K.
    571480KB, 592700KB, 648576KB, and 677369KB
    Camelot, U.K.
    One other thing I forgot to mention...and I, again, have no idea what this means nor necessitates...if I try to de-multiplex one of these X(S)VCDs with TMPGenc, the first thing that happens is a new box opens that says "Creating GOP List" which takes about 30 seconds to complete. Not sure what this means nor how I use a "GOP List"...any thoughts on this???
