Hi Peeps!
I'm hoping someone can make my day a little brighter and help me with this strange fault.
First of all I own an 'AMD Athlon 2700mhz', '512 MB Ram', running 'Windows XP' - With latest S/P.
The motherboard is a 'ASUS A7N8X' with onboard Sound. (NVidia with the lastest s/p)
I capture video from my analouge video camera through my Pinnacle Capture Card, using the software 'Intervideo WIN DVD Recorder'. I record directly into MPEG 2 DVD Quality, so it's the best I can get. (I don't bother editing, just capture and burn baby)
I go from my analouge video camera, directly in to my "line in" on my motherboard, with the level near the bottom, so it doesn't clip on loud noises!
My problem is: The video looks great, the sound is fine. However, if I have a constant sound, like a ferrari revving on the spot... it will sound like ... vrooooo *quiet vroom * vroooo *quietvroomm* vrooo
instead of vrroooooooooooooooooooooooooom
LOL.
Basically ,it's dropping the sound volume every other second on loud constant noise, so you get noise then nothing..... only noticeable when something constant is making a noise. Speech and everything else is fine, its just constant loud noise, you hear the dip in volume...
Its a pain in the backside! I never had this problem befoire, but I use to run Windows 2000 before... do you think it could be XP?
If this makes sense, can anyone give me a few pointers at all?
Results 1 to 1 of 1
my god!, where's the 'UNDO' button!! eeek
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 20:30 -
Pinnacle AV DV capture card
By pawan.bishnoi@gmail.com in forum Capturing and VCRReplies: 0Last Post: 30th Jan 2011, 13:45 -
Capture with DC 10 Pinnacle Card with OS Win 2k and Pinnacle studio11
By fjmr in forum Capturing and VCRReplies: 2Last Post: 7th Apr 2008, 18:02 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 08:35 -
Unknown Pinnacle Capture Card
By Signal in forum Capturing and VCRReplies: 6Last Post: 24th Jul 2007, 20:03
