When capturing video @ 720x480 through WinTV V'Dub displays a data rate of 6,800-7,000KB/s using the Huffyuv codec. Now, when I do my TMPEGnc encode to DVD specs is setting the bitrate to anything over 7,000KB/s wasteful, maybe even harmful (i.e. introducing artifacts)?
Appreciate any and all input.
Regards,
Golem
When you're capturing with huffuv, the bitrate is ~ 7000 kbytes/sec = 8 x 7000 kbits/s = 56 000 bits/s, so you're compressing your capture A LOT even if you're using th maximum bitrate of DVD specs, that is CBR 9800 kbits/s.
Think about it: an hour of captured huffuv material is about 30 GB, an hour of DVD material encoded with maximum bitrate is a bit over 4 GB -
Ahhh, great, thanks for making that subject a good bit more clear for me. I wasn't taking into account the "lossless" compression factor. And yes, the file size disparity was sittin' right on the tip of my nose but still I failed to see it! :-0
Best Regards,
Golem
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
When you say Encode it for X bitrate...
By Priapism in forum Video Streaming DownloadingReplies: 9Last Post: 12th Sep 2009, 00:30 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Xvid won't encode at the right bitrate?
By dimtim in forum Video ConversionReplies: 2Last Post: 18th Jul 2007, 20:58
