I can't believe it! I found a FREE CD/DVD burning software called Burn4free and only found one (1) hit on this forum. This easy tool is really good. It will make music CD's Data CD's and DVD's. I use it in conjuction with DVDShrink to back-up my DVD's. It is as good as Record Now Max only FREE. I give it two thumbs way up. Check it out here![]()
Oh by the way Adaware and Spybot found no spyware
Results 1 to 10 of 10
So, if you get a burning program in the package, you should dump it and look for a FREE burning program, instead?
I don't know what you are buying, but if I buy a burner in a box, it comes with a burning program.
Admittedly, the burner I bought over the weekend had NTI CD Maker in the box, which I have never heard mentioned on this site, but, since I replaced a LiteOn, feel that it is legal to use the Nero with the new burner.
Now, if you saved 2 bucks by buying n OEM with no software, cables, screws, etc., be my guest. Oh, yes, no warranty, either ( well, maybe 30 days ). -
Well, I saved more like $150.00 by buying a DVD burner that was pulled from new HP computers that did not sell and put back in the box. No software. So no, if you have burning software I'm not saying you should drop it and look for a freebie. But if you don't, and you don't want a hacked or cracked version of Nero or Record Now Max. Plus I've never had any luck with NERO and DVD backups. So if you need one get this
That's cool. All I did was put the info out there. Works great for me and I don't own any other DVD burning software.I think I will continue to use RecordNow DX.
My new Emachine came with a NEC1300 but the software isOriginally Posted by gmatov
Roxio EzCD 5 "Basic" which is "basically" only capable of burning data, ... no music, no video...
I wonder how much more it would have cost them to include a burning software with more capability?
I currently have Nero5 which I bought off internet last year for $9.
Thanks for the info, I'll try it.God Bless -
I tried giving Roxio another chance... upgraded years ago to EZCD Creator. Tried again with EZCD + DVD v6... and again I feel used, abused and ripped off. Roxio has terrible support - IF you can get them. I have never used a product of theirs to satisfaction. What a waste of money.
Stay away from anything stamped Roxio. -
I couldn't agree more Farnk... Imagine I paid for the shit and it never worked on my computer. If I had know that I could I get recordnowMax for free off the internet, I would have saved my money UGH
well i use nero 6 along side dvd shrink and iso buster + ulead dvd movie factory, works great for me, i say each 2 its own 8)
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
Can someone recommend a free mp3 cd-r burning software?
By Huh...What? in forum ComputerReplies: 6Last Post: 25th Mar 2010, 08:30 -
Free program for Burning extracted DVD files to disc?
By lglrgl in forum Authoring (DVD)Replies: 1Last Post: 25th Dec 2007, 11:21 -
Free soft for burning DVD LightScribe Disc
By fjmr in forum MediaReplies: 4Last Post: 1st Dec 2007, 22:01 -
which of the free burning programs is the best?
By nobbyiscool in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2007, 03:49
