Im new to the DVD burner thing and basically dont know anything about it. My problem is: I use DVD-RAM's to put my MP3's and such so they arent on my HD, well I have like 3 of them that are blank and when I put them in I usually just drag the files I want to put on them and drop them onto the drive in windows explorer. Well the last 5 or so I bought dont do anything, when I try and move files to the it says "please insert disc" like there isnt anything in the drive. Why does it do this and how can I fix it so I can get some of this stuff off my HD?
Thanks for the help.
Wish I could help you dude. I am not learned in the school of DVD-RAM. Ever considered backing up onto CD-R or DVD-R? How large is your collection? Might save you a bit of money to migrate to a different medium, I can imagine DVD-RAM discs aren't too cheap. Hope someone is able to help you with your problem.
-Free -
don't know but it soounds like they aren't formatted yet, or you need some kind of driver that reads blank ram. check for updates on your orignial dvd drive
how do you format them? I dont remember having to do it with the one I currently use?
I have used CD-r's but it takes so many of them comapared to the DVD-RAM.
Basic BD burning help please!!
By Aterlay in forum Authoring (Blu-ray)Replies: 10Last Post: 6th May 2012, 23:04 -
Basic external HD help
By Dash1 in forum Newbie / General discussionsReplies: 9Last Post: 23rd May 2008, 19:41 -
Basic Conversion ?
By Dash1 in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2008, 12:09 -
Basic requirement
By namya in forum Off topicReplies: 5Last Post: 3rd Aug 2007, 15:17 -
Very Basic Authoring Question
By Seeker47 in forum Authoring (DVD)Replies: 7Last Post: 10th Jun 2007, 21:24
