Can someone please post a solution to this? I'm sure there must be one, I just don't know what it is. I used TMPGEnc Plus to join a movie that was made up of 3 parts, so that it was one file. It plays perfect as an .mpg file, and the sound is in sync all the way through the movie, including the joined parts. Only thing is, after joining the parts, I attempted to make the new file DVD compliant with SVCD2DVDMPG so that I could then author it with TMPGEnc DVD author. When I attempted to do such, SVCD2DVDMPG started for a second, then stopped, reporting that the file I was trying to make compliant was not a valid .mpg file. I've searched the board and so far couldn't find any solution to fix this. Does anyone know if there's a way to alter the file so that I can then make it DVD compliant by using SVCD2DVDMPG? Any help would be appreciated.
Can someone please post a solution to this? I'm sure there must be one, I just don't know what it is. I used TMPGEnc Plus to join a movie that was made up of 3 parts, so that it was one file. It plays perfect as an .mpg file, and the sound is in sync all the way through the movie, including the joined parts. Only thing is, after joining the parts, I attempted to make the new file DVD compliant with SVCD2DVDMPG so that I could then author it with TMPGEnc DVD author. When I attempted to do such, SVCD2DVDMPG started for a second, then stopped, reporting that the file I was trying to make compliant was not a valid .mpg file. I've searched the board and so far couldn't find any solution to fix this. Does anyone know if there's a way to alter the file so that I can then make it DVD compliant by using SVCD2DVDMPG? Any help would be appreciated.Hello.
You posted this question in just about every thread BUT the SVCD2DVDMPG one!
Moving... -
Try demultiplexing it then remultiplexing it again. File/mpeg tools/simple demultiplex....and simple multiplex.
When multiplexing choose mpeg2 SVCD as the output type. -
Why not just convert to mpeg2 in TmpG and then use their authoring software to get the files ready for burning....Not bothered by small problems...
Spend a night alone with a mosquito -
If you join mpgs you can get problems. Try de- & multiplexing the mpg again or use another program to join.
But i can see why you want it cause if you join them in an author program you might see the transition. -
Originally Posted by yf2001usa
There is a file size limit (2GB) with svcd2dvdmpg. Don't join your mpegs anyway.
noise where joined 2 avi files
By coyote2 in forum EditingReplies: 20Last Post: 13th Oct 2011, 21:19 -
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 10:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 16:41 -
Joined VOB files... but length remains splitted?
By Metallo in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2009, 03:44 -
m2t files won't work in Vegas Pro 8
By Patokid in forum Newbie / General discussionsReplies: 12Last Post: 21st Jan 2009, 14:47
