Hi,
I am trying to put subtiles with a .avi for a vcd.
I was following this web site:
https://www.videohelp.com/srtsubsvirtual.htm
It seems to work pretty well, however, I got lost towards the end.
I see something like:
AVIFile only, it it says anything else install the Handler again as describe above. Don't click on the Stop Serving.
I got that far, however, now it says something like, which I am not sure how to get to the next step below:
Now it's time to Encode the frameserved video to MPG. Launch TMPGEnc.
Open the .vdr by select Files of types: All files.
And now it's just to select VCD Templates or SVCD Template and Encode, read more under the AVI to MPG guides.
There is no vdr file either, unless it is one for the virtualdub filters?
How would this be fixed? Please thank you.
How would the subtitles be fixed also if they are off a little? Please and thank you.
Results 1 to 1 of 1
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
