please can someone point me to the files i need to install to stop these errors - i am able to watch all DiVX and XviD videos on my PC so i assumed i HAD all the correct codec's![]()
here are the errors
VapoLianLi
2.4b @ 3.6
Abit IC7
512 Corsair XMS3500
ATi 9700 Pro
Pioneer 106 DVD-RW
LG DVD/CDRW Combi
Samsumg 181 TFT
2Mbit DSL :D -
Just being able to view an AVI, doesn't mean you have the necessary codecs to properly decode it, hence the error message your recieving. use GSpot in the TOOLS section to identify the codec used. It will also report if you have the necessary codec installed.
The codecs your looking for are XviD, and DivX 3 Low Motion codec (3.11 Alpha may work). You can find both in the Nemo Codec pack, or just browse the CODECS in the TOOLS section to download what you need individually.Impossible to see the future is. The Dark Side clouds everything... -
many thanks kind Sir
VapoLianLi
2.4b @ 3.6
Abit IC7
512 Corsair XMS3500
ATi 9700 Pro
Pioneer 106 DVD-RW
LG DVD/CDRW Combi
Samsumg 181 TFT
2Mbit DSL :D
After Effects error: opening sound component (-2166)
By santolina in forum EditingReplies: 0Last Post: 24th Apr 2010, 08:36 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33 -
error when opening up mkv file with virtualdubmod
By parth82390 in forum Video ConversionReplies: 5Last Post: 5th Dec 2007, 18:00 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 13:53 -
Error when opening avs in VirtualDubMod
By chrishallowell in forum Newbie / General discussionsReplies: 6Last Post: 28th Aug 2007, 07:57
