Burnt a DVD, with VCD films.
1st bin/cue 2 chapters
2nd mpg
3rd bin/cue 3 chapters
1st and 3rd play fine, 2nd (title 2) after about 20 seconds jumps to new 3rd VCG.
If you forward though it, you can go though the whole film, however soon as you press play, 20 seconds ish later you loose film again.
Any ideas what could cause/caused that effect ?
Results 1 to 11 of 11
Guest
hard2handleGuest
I have the same problem.
have start an session with 4 vcd´s / svcd´s and an menü...
i can choose the film in the option menü and than the movie hang after 20 - 30 seconds..... but i can jump to the next chapters around the dvd.....
this happends on 2 dvd player´s
Sony DVP-S 335
Pioneer DV-444
than i gave an very cheap model an try...
on this player .. the dvd run without problems.....
now i test the same with the Pan & scan option ....
maby after this the dvd work on my pioneer.....
someone have an idea ?
sorry the bad english -
hey,
I can't try it for you cause my version of 1.5 isn't working.. But you might want to skip addind chapters and see what happens
Greatings,
Yf -
yf2001usa: whats your issue?
dd-Guest
I have a pioneer dv-c503 and have the same problem when buring 4 vts (4 vcd's) into one dvd. I tried to burn 1 vcd into a dvd just to check that my player will work with dvcd's(it worked). I used svcd2dvd+ for both trials. I will try and burn using version 1.5 and give you guys a update....Still It is very exciting new software with great support from likeminded people.
Can anyone confirm whether this is just with VCDs or just SVCDs or only when combining?
Guest
Most of you dvd players wont play patched vcd/svcd DVD....
I have give the program an try... but on my 2 dvd players my dvd wont work.... but on to other the dvd work without problems.....
but an relaay problem is the async with mvcd´s.
after the sound changeing from ssvcd2dvd many mvcd´s are async..
someone know whats up with this point ? -
async:
Look at the sticky post: Installation & Common Issues (including AV sync)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guest
tried again using version 1.5 using 5 vcd's (some pal some ntsc). result was disappointing. it played good in my computers 2 different dvd's but did not work in my standalone pioneer CD player. picture would lock up after a few seconds. probably for the better, the compilation I was making was a bunch of cartoons for my kid..he already watches to much t.v. I will try again tonight with the 'pan and scan' button checked and see if that works.
iDVD bombs out during the middle of encoding
By Nilfennasion in forum MacReplies: 6Last Post: 9th Aug 2011, 12:52 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 09:44 -
Middle Surround
By ranosb in forum AudioReplies: 0Last Post: 27th Jul 2009, 17:35 -
shutdown in the middle of ConvertX
By doodoobrova in forum Authoring (DVD)Replies: 3Last Post: 8th Feb 2008, 19:32 -
problem converting one little file to mpeg MOV (any ideas why)
By bdaul in forum ffmpegX general discussionReplies: 5Last Post: 1st Jan 2008, 09:32
