me crazy.. for some files I have to use different versions of the XVide codec and some work and some do not work. They are some live concert files. Someone mentioned that the ffdShow can replace the Xvid but I tried it but it works about 70% but 1/2 still it breaks up the images like a kaleidoscope of funky colors.. maybe I should try next is a hammer on the monitor.
You need only the newest version of XviD. Are you sure your not referring to DivX? That codec has multiple versions, all of them distinct from each other ( Divx3 Low Motion, DivX 3 High Motion, DivX 4, Divx5 ). Even with DivX, once you install each of the codecs above, your all set.
Impossible to see the future is. The Dark Side clouds everything...
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
Looking for a Video Converter to convert files to various codecs
By JohnFB in forum Video ConversionReplies: 0Last Post: 15th Nov 2010, 00:57 -
Conversion size is driving me crazy!
By artdog in forum DVD RippingReplies: 8Last Post: 27th Apr 2009, 12:33 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55 -
This file is Driving me Crazy! suggestions plz
By k_oss_22 in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 00:40
