From my understanding, Studio 8 uses constant bitrate when compressing an avi or mpeg to fit on a dvdr. I would like to use Studio 8 to capture and edit - create transitions and menus - but use another application such as dvdshrink, instant copy, dvd2one, etc. to compress the resulting file to fit onto a dvdr.
Is this possible or are these programs only for dvd to dvdr?
Studio 8 has worked well for me for capturing and editing. But you can not compress the captured video by the likes of DVD Shrink. You'd need a different class of software altogether. Firstly, you'd capture in AVI format. One hour of video would take about 13 GB of space on the hard drive. Then after editing, you would save you save it as a new AVI file. You need another 13 GB of HD space for that. Then for compressing (it is actually called rendering, or encoding), you need one of the following:
TMPGEnc
Cinema Craft Encoder (CCE)
Main Concept
All of the above are very good. The resulting file would be an "mpg" file. You need to use the right kind of settings to get a VCD, SVCD, or DVD compatible mpg file. The file size would varry depending on the bit rate setting.
Hope this helps.
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 05:55 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29 -
Edit 3 cam's with Pinnacle Studio 12 Yes you can
By Habby in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:28 -
edit studio 6
By m baqar in forum Authoring (DVD)Replies: 0Last Post: 6th May 2008, 23:02 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
