Hi people,![]()
Is it possible to connect my satelite-receiver
to the PVR-350?
So I can capture without noise.
Scart-Out(satelite) TO-> ??? (PVR-350)
Because I got noise on my analog-cable connection and I want to use the satelite-receiver.
Please, I can use your help.![]()
DeepX
***May the force be with you! Always...***
I believe the PVR-350 has S-video and composite video inputs, but your satellite receiver probably isn't capable of outputting in S-video. You will need a scart to triple phono cable (go to www.maplin.co.uk and check product code VA11M, you should be able to find something similar in your area). This will give you three phono plugs coloured yellow, red and white. These are composite video (yellow) with the red and white being stereo audio. These need to be connected to the matching inputs on your PVR-350.
Thanks man!
I'm sure gonna give that a try.
(say bye bye to noise-tv!!)
DeepX***May the force be with you! Always...***
Recording satelite TV with Panasonic DMR EH59
By bjuice in forum DVD & Blu-ray RecordersReplies: 20Last Post: 3rd Sep 2012, 18:22 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Satelite USB Capture?
By wulf109 in forum Capturing and VCRReplies: 12Last Post: 6th Jun 2010, 17:58 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05
