For anyone who has an AIW card using MMC, what does "Capture cropped video" do?
It removes [crops] the overscan area of the screen, which is typically either black or noise. It avoids wasting bitrate on invisble parts of the screen.
You should only enable it with MMC 8.1+, as older versions would make the file not compliant for VCD/SVCD/DVD burning. -
I use MMC 8.1, and it'll capture at 338x448 (on 352x480 with cropping), which makes the video non-compliant.
Sulik, how? I saw your review of MMC, and it left me scratching my head... I'm curious what you did.
Even if I did get it to work, "cropping" stretches video, which I'm not always fond of. I normally prefer to "mask" or "clip" the overscan with black mask. But neither MMC nor any other capture program does that, only encoders/editors like Premiere, Procoder, MainConcept, and TMPGEnc. Though, cropping does have it uses when the overscanning or other errors bleed onto the screen!Want my help? Ask here! (not via PM!)
Would there ever be a reason to capture "upconverted" video?
By yoda313 in forum Capturing and VCRReplies: 11Last Post: 20th Mar 2010, 21:26 -
another "which to buy" video capture equipment
By CNT in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2010, 14:10 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 13:14 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
S-Video capture produces "crosshatch" noise
By scootdogg in forum Capturing and VCRReplies: 11Last Post: 4th May 2007, 12:53
