Can anyone help? I already know how to encode to DVD video normally.
This guide https://www.videohelp.com/forum/userguides/91588.php here should help you to extract the Ac3. The encode the video and either multiplex the Ac3 file with the .m2v or let the authoring program handle that bit.
Thanks for that. I know that part but what else do i do to make the DVD play 5.1? There must be another toturial for the rest of the process.
Here's the process in short:
1/ Extract AC3 audio file /with Virtualdub/
2/ Fix the AC3 file /it's usually messed up/ with AC3fix as follows:
Start>Run>cmd. You're in DOS window now /Before this put AC3fix in the same directory where your AC3 file is/.
Go to the directory where your AC3 file is. Type:
ac3fix extractedaudiofilename.ac3 fixedaudiofilename.ac3
You can now use the fixed AC3 file for authoring/muxing.
3/ Author/Mux audio and video with an appropriate program.
That's it!
Enjoy!
5Ch and 5.1Ch
By socrates in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Apr 2012, 23:40 -
Possible to convert a 5.1CH 4608kbps PCM audio track to a 1536kbps 5.1 DTS?
By fluxcapacitormb in forum AudioReplies: 4Last Post: 20th May 2010, 15:46 -
Mark 5.1ch Files
By lgare in forum AudioReplies: 2Last Post: 7th Jan 2010, 07:48 -
AAC 5.1CH audio plays as 2CH on my DSM-750 media player
By roise_r in forum AudioReplies: 0Last Post: 22nd Aug 2009, 23:45 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22
