I was able to successfully convert a PAL DVD to a NTSC DVD. However my process loses the Menu and subtitles. I would like to keep the subtitles though, so I need help there.
I can RIP Vobs or demux streams and convert these files to a usable DVD format but the quickest process is the following. Here is a paraphrase of my process:
PROCESS
1. 10-15 Mins Total
Rip the Movie-only in file mode with DVDdecrypter
2. 3-4 Mins Total
Rip the AC3 audio from each VOB using DVD2AVI
3. 30-45 Mins total
Convert each the 25 FPS/PAL VOB's to 29.97 FPS NTSC MPG's
using Main Concept Encoder.
4. 20-25 Mins Total
Use Tmpeg Author to remux the NTSC MPGs and AC3 audio to usable
DVD vobs and IFOs.
5. Variable Mins
Must retranscode these files (usually 6.0-6.1gb) to 4.7GB and burn
The resulting picture quality and audio sync is suprisingly really good.
However, I would like to retain the subtitles - what is a good process or product to do this with? Tmpeg Author can not use the .SUB file basically it can use only video and audio files from the looks of it.
So subtitles looks like something I need to do before I get this far or maybe I need to use something else, entirely?
Can any one help me?
Thank you
