When exporting my iMovie to DV quality .mov's sometimes the .mov won't work in ffmpegX. When I try to load it ffmpegX gets stuck and only after 2 minutes or so the .mov is loaded. When I try to encode it (DivX(libavc) PAL) it won't encode, it just repeatadly shows the error message:
Encrypted VOB file (not compiled with libcss support)! Read DOCS/cd-dvd.html.
What does this mean and why won't it encode, while other movies DO encode? If I trie to export it again the same problem occurs with that iMovie.
" Military intelligence is a contradiction in term."
- Groucho Marx
Problem wit .MOV files on iMovie
By Maurem in forum MacReplies: 5Last Post: 9th Sep 2013, 00:54 -
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 00:40 -
xdcam to .mov so I can edit with iMovie????
By boriega in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 00:39 -
Problem with converting MOV files from iMovie / Camera
By pred02 in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 02:25 -
VOB to MPEG to MOV to export to iMOVIE HD 06 HELP PLEASE!
By HowardNeedsHelp in forum MacReplies: 5Last Post: 16th Aug 2009, 06:15
