  1. Hello , i'm currently working with a DVD ISO image file which is supposed to be burned using DVD-R...
    However, i own a DVD+R drive and to my knowledge, the ISO will fit on DVD-R
    (and not DVD+R)..
    Help!
    The ISO image is exactly 4,703,617,024............(so won't fit on DVD+R)
    Is there any way of overburning to get it to fit..?
    p.s. i got some info about capacity of DVD+R and DVD-R,... kinda
    explains what i mean..
    Blank DVD-R 4,489MB 4,706,074,624 bytes or 4.383GB
    Blank DVD+R 4,483MB 4,700,372,992 bytes or 4.377GB
    Any help would be very gratefully received!! TIA!
  2. I don't think this 3MB would be a problem when burning ISO
    BTW burning programs usually have a TEST option before burning
    Something like:
    "Test and if OK then Record."
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  3. I just checked: our drives don't support testing before burning DVDs.
    I'd just give it a go and write that ISO with DVD Decrypter
  4. thanks for your reply, but i am curious if it is possible to 'Overburn'
    data onto DVD..?
    Normally, when i burn disk it says... (Not enough space on disc..)
    I burned the iso with DVD Decrypter....and had an error at 99%... it then closed the disc and finalized it...
    Is it possible to overburn...with DVD...or is this a myth?
  5. Originally Posted by Renegade_UK
    And does it play?
    Both RecordNow Max(DX) and Nero support overburning but I don't know if it will give you any good, that space just seems too tight.
    Try it, if it doesn't work you need to cut a couple of frames off your movie
    its 3MB only
