I have just bought a Sony DWU-10A DVD writer. The problem I am having is that it can't read a DVD-RW disk. It always reports 0GB when you look at the properties. Nero says that there is no disk in the drive.
It did manage to recognise the disk once, but has never again. It can read CD's and CD-R's OK.
I'm also having a problem in that when I try to update the firmware or use the program DVDInfo or DVD Plus Identifier, it just reboots my PC.
I am using WinXP Pro and have the drive in IDE1 as master. There is no other device on the cable.
Any ideas?![]()
I have the same writer, still on original firmware 1.1a.
Does the drive see a -r or a +r disc ?
I take it Windows identifies the drive correctly, jumper set on Master.
I can only think it is a media problem.
I mainly use white label gold edition -rw x1 and have had no problems.
Have also used a x2 -rw Datarite (green label).
Update to the latest version of Nero .42. I have had problems with Nero 6 and gone back to 5.5.
Maybe try a different brand of disc.
Hope that helps.
dlb.
Sony DAV DZ 260 does not read any disks
By vladc64 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Feb 2012, 05:58 -
Sony Wants to upgrade my Ps3 or refuses to play disks.
By cal_tony in forum DVD & Blu-ray PlayersReplies: 22Last Post: 20th Apr 2011, 22:17 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Insignia NS-LDVD32Q-10A - need region hack/unlock
By xisle65 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 12:17 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
