Hi I use DVDshrink to rip files from a DVD-9 how do I burn the files i pull off the DVD-9.
Results 1 to 26 of 26
Drop'em in Nero Express as DVD-Video and press burn
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
ChaosMath, you'll find a couple of Nero user-friendly guides at DVD Shrink.info.
I opened Nero and put it in to Nero Express mode clicked on DVD Video files then put all the files that I got from a DVD-9 with DVDshrink and put them in Nero Express and burnt to a DVD the DVD cant be played on my DVD player does any one know what I did wrong..
ChaosMath, you probably forgot to put the files in a "VIDEO_TS" folder first.
Read these guides for a more detailed explanation.
http://www.dvdshrink.info/guides.php
They were made with Nero 5 but the principle is the same.
Wrong. Nero Express automatically creates the VIDEO_TS and AUDIO_TS foldersOriginally Posted by ddlooping
if DVD-Video is selected, and accepts only VOBs, BUPs and IFOs then puts the in the VIDEO_TS.
Try Nero Burning Rom instead and use UDF/ISO 1.02 as ddlooping says
http://www.dvdshrink.info/nero-udf-iso.phpYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Oops, sorry.
I didn't know Nero Express created the VIDEO_TS and AUDIO_TS folders.
RecordNow Max trial version is free for 30 days
http://www.stompinc.com/trial/index.phtml?stp
You need t install the pxEngine update too.
http://support.sonic.com/Downloads/engine.asp
Be aware it could be a media incompatibility, player or burner problems, etc...You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
You obviously haven't read the whole threadOriginally Posted by andydd
I already said thatYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I still cant seem to burn DVD files after useing DVDshrink I tryed Nero and Nero Express when I put the DVD in my Pioneer DV-353 it says can not read disc so is there another way to burn thees files please??
Lets see what DVDInfo PRO says about your discs (with the movie on it)
ChaosMath, did you try the UDF/ISO mode in Nero?
Your Pioneer DV-353 might not be compatible with the DVD-Video one.
If UDF/ISO is still not working, try RecordNow Max as tompika suggested (in DVD Data mode).
If you haven't already done so, I'd also suggest you use DVD-RW until you find a solution. -
I use the program above and the following info was on the disc I burnt this disc useing Nero Express by selecting the files and and adding them to Nero Express
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID MCC00RW11N9
Format Capacity 4.13GB(4.44GB)
Free Blocks 0
Book Type DVD-RW
Media Type DVD-RW
Media Id Code Speed 1.0x 1385KBps
Available Write Descriptor CLV 1.0x 1385KBps
Write Strategy Speed 1.0x 1385KBps
Data area starting sector 30000h
Data area end sector 210DDAh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1 -
It should say DVD-Video UDF 1.02Originally Posted by ChaosMath
You do something wrongYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
ChaosMath, you could try RecordNow Max (already suggested to you twice).
Here is a link to the trial version:
Just to satisfy my curiosity, did you try UDF/ISO in Nero???
http://www.dvdshrink.info/nero-udf-iso.php -
Hi does any one know how to burn the files i pull off a DVD-9 with DVDshrink and burn them with RecordNow Max and/or burn4free please can you tell me step-by-step thanks
I noticed several comments about Nero's creating of the Video_TS folder that is needed. My question, ChaosMath and others, is did you drag the files into this appropriate folder or does Nero have enuff sense to do that part for you? Perhaps, ChaosMath, you merely drug the files to the layout itself, not the Video_Ts folder like you should. I've only used Nero once, since Copy2DVD is idiot-proof and has never given me a bad burn with my files. Perhaps you could try it. I guarantee there's about a 1 second learning curve, if that.
Take the files that DVD Shrink produces NOT the folder and place them nside the VIDEO_TS folder that NERO produces along with a AUDIO_TS folder NERO produces when used in DVD/VIDEO mode. DO NOT put the FOLDER that DVD Shrink produced, just the files that are inside it. It could not be simpler. I'm up to backupt # 177 with DVD Shrink. Some with no compression but most with some degree of it. You will discover that some movies WILL give you trouble. If I can't backthem up using the sittings that work for all others, I don;t wast time or materials trying to back them up. Sometimes it's just an exercise in futility. Download the newest DVD Shrink 3 Beta 5 if you want to continue to use it. I use NERO 5.5.10.50 as I have not have good luck with V 6. You have to disable AMAPI but that's another story.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Don't forget to check your players compatability with media and programs etc. in the player report section. My best player (Sony 530) would not play any kind of cd/r disks but cd/rw were fine. It's possible your player is rejecting the media, burn program, or maybe something else.....
Glad to hear that, ChaosMath.
How do you edit VOB files from DVDShrink to mute same audio portions?
By soundoff in forum Newbie / General discussionsReplies: 3Last Post: 11th Mar 2012, 19:58 -
need to use dvdShrink but my video has no video_ts or vob files
By redbourn in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jul 2011, 23:08 -
problem with DVDShrink finding files
By chaskar in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2010, 16:48 -
Video_TS Files (DVDShrink) to DVD
By ione in forum Newbie / General discussionsReplies: 7Last Post: 26th Jan 2009, 22:18 -
DVDShrink - Where are the dump files
By mn072065 in forum DVD RippingReplies: 15Last Post: 25th Feb 2008, 07:48
