  1. Whenever I use DVD2SVCD with CCE (SP 2.62.01.01) set as the encoder, CCE crashes when the encoding begins. (Just after the VFAPI script)
    It gives an error & exception code about not being able to read or write to memory. I should have wrote down the full msg, sorry.
    However TMPGEnc works fine. Is this a commen problem with this particular version of CCE. Maybe I'm missing some additional software?
    I hope someone can shead some light on this one.
    Thanks in advance
    XimeR
  2. diANA Troi "I sense agitation, captain and ... confusion"
    picard "what could it be, number ones??"
    troi "No, i think he's using an athlon processor"..
    You have to include an audio resample thingie in your script otherwise it can crash. or it might be somethinh simpler. I hape I heve shed light. :P
    The electronic components of the power part adopted a lot of Rubycons.
  3. Originally Posted by RabidDog
    Doesn't DVD2SVCD do all that for me?
    Bromley, UK
    his is only if you are using an Athlon Processor - (there is a tick box in the Audio tab part of DVD2SVCD). DVD2SVCD has known problems with CCE above version 2.50 - if you look at the DVD2SVCD.ORG web page it tells you how to overcome most of them...
