If u have an avi and want to make a dvd to play on a stand alone dvd player, u also want to have 5.1 audio.
Which software to convert ?
Which software to burn with?
I have never done a dvd so i am really a newbie...And there is a lot of different software..
There are many possibilities, everyone has their own views.
Try a forum search. -
For 5.1 sound, you would need an AC3 encoder that supports 6 separate audio streams - Vegas Video will do the trick... or you can try Soft Encode but that is no longer sold and has been enhanced and integrated into Vegas Video
For authoring you'll need software that supports AC3. DVD Lab do the job. -
Encoders (what you have dubbed conversion software) are a realm unto themselves within video and everyone has their preferences. Some encoders do the job better than others. I personally prefer MainConcept (either standalone or the one integrated into Vegas Video) since it is faster than TMPGEnc but your mileage may vary. Some folks like TMPGEnc better and others swear by Cinema Craft Encoder (CCE). It's a matter of taste, cost, and what suits your needs and budget best. I would recommend Vegas Video for a greater part of your DVD needs, personally.
-Freestyler -
By "make" 5.1 audio I thought you meant create an original 5.1 ac3 audio streams from 6 different channels. Are you looking to just make "back up" dvds? If that's the case try DVD Shrink and burn it with Discjuggler, Nero, or Prassi. What format is your avi source file, Divx?
Sorry bout not making myself clear.
Yes it's divx and audio has 5ch when u look at the file in virtual dub.
Best software for making concert tv commercials?
By voice903fm in forum Newbie / General discussionsReplies: 12Last Post: 12th Sep 2011, 10:36 -
Making documentaries: Camera and software suggestions?
By nopEda in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2008, 16:07 -
free software for making cd-rom iso's
By Dr.Gee in forum ComputerReplies: 1Last Post: 27th May 2008, 18:00 -
Best freeware software for making WWW sites
By deejay.2001 in forum Off topicReplies: 7Last Post: 20th May 2008, 02:05 -
How do I start making my own Software?
By Nitro89 in forum ComputerReplies: 16Last Post: 19th Feb 2008, 23:59
