  1. I am converting avi (xvid) to SVCD with TMPGenc.
    I have converted the audio with Virtualdub.
    When encoding the 2nd SVCD I get this error:-
    "Index of scan is out of range (320)".
    I made a search in the forums and found a couple of subjects to do with the matter.
    I used Virtualdub to scan the videostream (as mentioned in one of the posts) and got this message:-
    0 frames masked (0 frames bad, 0 frames good but undecodable).
    Anyone got any other ideas for my problem please?
    Thanx.
  2. When you say you converted the audio, to what ?
    If it's wet, drink it
    My DVD Collection
  3. WAV.
    1411kbs, 16 bit, stereo, 44kHz.
  4. Dun matter now, I sorted it!
    Instead of encoding half the file for SVCD, I dun the whole thing and split the mpeg in half.
    Thanx.
