Im tryin to cut down a 703mb file to 701. I tried using avichop, but it doesnt even work. I tried chopping it and left it on all day to come back to see that it didnt do jack. What program am I supposed to use and how do I set it up? I wanna delete a little of the beginning to fit the divx on 1 cd
i followed the instructions to that link, and it messed up more. It cut the file size down, but the beginning scene i deleted was still there, only it was going real slow. throughout the movie the video was choppy. What the hell?
Did you mark start and end at keyframes (Yellow key) and select Vidio > Direct stream copy ?On 2001-10-02 02:01:29, iluvJLO wrote:
Ok... I re-did it. It did chop off the scene I selected, but the video is still choppy. it'll freeze and play, freeze and play. The fps is set at 23.97 but is running at like 4.29-10.27... it varies, but whatever. The video aint playing smoothly. What am I doin wrong? I had both video and audio on direct stream copy
I have the same problem, with slow and choppy files,
and besides that, what is the codec i really need for VD ?
I have AngelPotion and VD sertanly dosent like that one....
without that however i cant watch anything at all,,
so i need a codec...............
AVI Videos Cutting Out
By Blade of Tyshalle in forum Newbie / General discussionsReplies: 11Last Post: 8th Feb 2012, 12:49 -
help cutting an AVI file
By ethandeitrich in forum EditingReplies: 2Last Post: 24th Oct 2007, 00:25 -
cutting a few frames from an avi
By tommid in forum Newbie / General discussionsReplies: 7Last Post: 17th Oct 2007, 18:52 -
Cutting avi's with APE 3?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 12:35 -
Cutting AVI without all the re-encoding
By gameroftheuk in forum EditingReplies: 6Last Post: 31st Aug 2007, 22:13
