Hi,
Is there anyway to convert a DVD+R to a DVD-R ?
Thanks in advance for help.
Originally Posted by qiau
just rip the dvd+r to an iso file (i suggest dvd decypter) and then burn the iso file to the dvd-r..
its very simple.. no conversion -
Exacly what all the other fellas said.
Just make sure the drive you are reading from can read dvd+r
and also make sure you have a dvd-r or a dvd+/-rw drive
Also if you have a mac
dvd+r is hard to deal with sometimes very easy to make a functioning +r disk but hard to recopy
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35 -
trying to convert old vhs tapes to dvd, used sony direct to dvd, not good
By hygieneboy in forum Capturing and VCRReplies: 27Last Post: 4th May 2009, 13:57 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 01:26 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 04:04
