I converted to SVCD a DVD , after the conversion I got a wonderful SVCD file. The DVD I converted was widescreen and on the top part of the image after the top black bar there are one of two lines of video that look a little clearer that the rest of the image. I checked the DVD on WinDVD and in a home player and the problem seem to be in the DVD. Is there something wrong in the DVD?. Anyway my question is How can I add to black lines to cover the clear ones. In other words I’ like to make the top black bar wider without changing the format of the video. Is this possible? I’ve been reading about cropping , is that the way I should do it? I just wanna add some lines. I don’t know if this is the right forum to postbut I don’t know how to fix the problem. Any advice? What program sholud I use? My apologies and thanks in advance.
Results 1 to 1 of 1
Top & Bottom border
By burgin in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2011, 18:31 -
black border problems
By nospam7676 in forum Video ConversionReplies: 2Last Post: 25th Dec 2010, 16:23 -
encoding black border or not ?
By miss in forum Video ConversionReplies: 1Last Post: 3rd Sep 2009, 09:27 -
Top border intrusion with Vdub Deshaker plugin.
By brassplyer in forum EditingReplies: 2Last Post: 6th Jan 2009, 10:29 -
Black border around conversion
By trueman in forum Video ConversionReplies: 8Last Post: 26th Jul 2007, 05:50
