Hi-I am using nero to author and burn a svcd. When i drag the mpeg2 into the window and nero scans the file it always says that the file is not in standard svcd form even though i use the tmpgenc svcd NTSC template without any changes. I can bypass this and still write the file, but does this mean that it is not in an optimal form to play on my standalone? Does this happen to others as well? Does anyone know a way around this? Thanks in advance for any help.
first of all
you have nothing to worry about it will probebly work
nevertheless if you want to be sure
multiplex the file again with tmpeg
or try to encodewith other encoders
I keep getting write errors in Nero - help :(
By Akhet in forum ComputerReplies: 11Last Post: 30th Oct 2009, 13:51 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Nero 8 DVD menus simulate fine but transcode errors on final dvd movie
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 03:01 -
burning errors in nero & tmgenc dvd3
By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 11:23 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22
