Theres a song thats only available on dvd that I want to use but Im having problems finding out how to rip audio from the "Extras" section of the dvd... Its only about 4:10 and is shown as a "Music Video"... What can I use to rip it or even how can I rip it as a movie and then extract the audio from that file?
Results 1 to 12 of 12
DVD2AVI will do the job. Find which VOB the audio corresponds to and load it up in that software. Select the (im assuming here) dolby digital track under AUDIO and hit Decode, then go to audio 48 > 44.1 khz and select Ultrahigh. Then go to Save Project and point to a folder and it should decode a 44.1 wave file for you to convert to mp3 or burn to a cd, or edit in your sound software, etc
Smart Ripper has an option to split the movies into it's elementary streams. You will get an m2v (video) file and an ac3 (audio) file. No need to take the extra step with DVD2AVI.
However, if you want the audio in a wav format DVD2AVI will decode it for you. -
Bringing this topic outta the grave
So I tried it all and I think I stumbled my way to ripping something wrong outta the dvd, but then my dvd drive crashed and burned out. So all this time later I finally got a new one and Im drawing a blank again.
Explained slowly, whats a VOB and how do I determine which VOB si the right one I want? -
"Explained slowly, whats a VOB and how do I determine which VOB si the right one I want?"
VOB=Video OBject
Use DVDShrink to find the extra you want then use VOBEDIT to demux and AC3Tool to convert.
...or you can play the extra on PowerDVD and capture the sound with Audacity,not as good of quality but a hell of alot easier. -
Here is a guide on how to do it in my sig below.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
#1 DVD Audio Ripper is what you need.it can rip dvd audios to mp3,wav,ogg,wma.support to edit start time and end time.
http://www.apollo-tech.com/dvd_audio_ripper.exe -
I agree with Massbit in selecting #1 DVD audio ripper as the tool for extracting sound from DVD. It is easy to use.
Rip audio from DVD chapter
By TYLER08027 in forum DVD RippingReplies: 3Last Post: 11th Jul 2010, 15:16 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
My DVD rip w/ no audio
By towarmforacoat in forum DVD RippingReplies: 1Last Post: 28th May 2009, 12:03 -
Audio Rip from DVD
By MI6 in forum AudioReplies: 1Last Post: 8th May 2008, 05:32
pen DVD>right-click on video and choose Copy>hit Reauthor>Paste>Backup.Then use
