I bought your awesome program and love it. I have a capture card and use WinDVR 3.0 to capture svcd 480 x 480, but when I go to use them in SVCD2DVD 1.5 it says no mpg, vob or bin file? I think the file extensions it uses it mpeg? Also I miss the mpeg info properties on the right click any chance on that being re-added. I love your program, don't get me wrong, I just hope you can help me figure out what to do with my mpeg-2 files? This would make my life so much easier, because I have a ton of the mpeg-2 files onmy HD I would love to put on a DVD. thanks in advance.
Vegeta_RVPPC2k3Guest
I think what you really need is just a dvd authoring program as your files are already dvd compliant. Something like TEMPGnc DVD Author will do the trick.
Not bothered by small problems...
Spend a night alone with a mosquito -
You need to select the directory containing the file(s) you want to convert, not the file itself.
if you have *.mpeg files - just rename them to *.mpg
phantomGuest
Yes, rename the mpeg's to mpg. I captuer with the same software and use chrissyboys software to put to dvd.
sounds like a fix request! :P
on the case!SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Author AVCHD from .mov files?
By p_l in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Jan 2011, 22:19 -
How to change AUTHOR, TITLE, ETC. of mov, avi, mpeg, wmv ??
By weezer76 in forum EditingReplies: 4Last Post: 28th Sep 2010, 17:02 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Need TMPGEnc Author help for .mts files!
By Woodserr in forum Video ConversionReplies: 4Last Post: 13th Jul 2009, 11:09 -
How do I Author an HD-DVD using mkv files....
By ronorkis in forum Authoring (DVD)Replies: 2Last Post: 10th Dec 2007, 12:47
