I have BeSweet installed in my computer from the SVCD2DVDMPG+ installation, when I clicked on the file icon to the right of the AC3 under the Audio Encoder and select either the besweet.exe or the ac3enc.dll, I would get the error message "Invalid AC3 encoder". How do I get the program to use the Besweet AC3 encoder? Thanks.
ats-65Guest
Hey,
If you got the newest version of svcd2dvd then i think you can't cause chrissyboy had to remove besweet from his program from the authors of besweet..
Greatings,
Yf -
ats-65Guest
Yes, I do have the latest version SVCD2DVD. However, I also tried with the SVCD2DVDMPG+ and got the same error. By not having the AC3 encoder, does that mean I cannot author DVD with SVCD files that have AC3 encoded or it only means I cannot convert my sound track to AC3?
The later.. you can't convert to ac3 if it has ac3 you just don't covert the audio with svcd2dvd.
Greatings,
Yf -
The only AC3 encoder which SVCD2DVD supports is Sonic Foundry's SoftEncode. It is very high quality compared to BeSweet/ffmpeg ac3enc.dll.
It is however no longer sold.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Need new non-AC3Filter AC3 decoder from Expression Encoder
By CasanovaFly in forum AudioReplies: 17Last Post: 30th Jun 2011, 17:41 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
DVD-compatible AC3 Encoder
By roflwaffle in forum AudioReplies: 2Last Post: 14th Apr 2011, 14:42 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
How to encoder file with AAC/AC3 in TMPGEnc Xpress 4 (English version)
By roc255 in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 17:57
