Hey, I need to know where to get logoaway (can't find the link) and some basic info on using it. Thanks!
If you want logoaway then do a web search for "logoaway."
Theres nothing to know about how to use it really. You put in the size of the area you want to edit and you move it where you want it. you have several options as to how you want to blend it, x, y, xy etc.. Just click on them all and see which one looks best, it will be obvious depending on your video source.
Logoaway
By syncro in forum EditingReplies: 5Last Post: 24th Dec 2015, 00:57 -
Avisynth script to blur, similar to Logoaway XY (mode)
By jairovital in forum EditingReplies: 18Last Post: 6th Aug 2011, 07:24 -
Logoaway and ffdShow
By syncro in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2009, 13:23 -
Logoaway filter for AviSynth?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 04:30 -
Using Logoaway in two-pass mode
By AlanL in forum EditingReplies: 1Last Post: 21st Jun 2007, 06:54
