I just bought an Iomega Super Drive - all of my soft ware detects the max burning speed of the drive as x2 not x4- is anyone else having the same problem - It wont even recognize 4x DVD-R Ive ruined 2 x4 discs of differnet brands - And Iomega wont help me - theyre useless - telling me to disable UDMA for the burner and use PIO mode instead- what a load of crock!!!!!
From what I understand... the IOMEGA drive is the same as (or very simular to) the LG GSA-4040B DVD-RAM drive. I have the same problem, only the DVD-R speeds are slow. There is a newer firmware to fix this but its for the 4040b. Maybe there will an update for the IOMEGA as well. Hope this helps some.
Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
Iomega are finally doing something for me - they are giving me new firmware - only after I threatened to go public to the Australian computer media I just hope it works Thanks again -
Any update on this problem? Did the firmware fix it? Thx.Originally Posted by cbourlSwift Kick In The Butt $1.00
try deleting your Secondary/Primary IDE controllers in hardware profile and restart.
This fixed a speed issue for me.THIS has been an RVL123 production...
SUPER - DVD Conversion?
By MVW in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2010, 16:02 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
AVI to DVD-MPEG2 using SUPER
By hemang in forum Video ConversionReplies: 0Last Post: 19th Jul 2009, 23:25 -
SUPER DVD CREATOR 9.25.0 Question
By Jboogie70 in forum Authoring (DVD)Replies: 2Last Post: 24th Aug 2007, 06:53 -
using SUPER to convert a DVD to MP4
By snafubaby in forum Video ConversionReplies: 1Last Post: 8th Aug 2007, 16:43
