I have a ISO file 712 mb im trying to put on cd. The problem is when I use nero img tab under "File" for burning I get my first error about block size. Theres only 2 choices to choose from, I tried both and neither worked.
Also I get a error saying there isnt enough space on cd for burning file.
I also played with the settings but it wouldnt finish at "disk at once" or could not perform end of track.
Help me please, I need to burn this file.
I run into this every now and then too. There are two things you can try:
Try burning the iso with Alcohol 120% instead.
Extract the MPEG file from the iso with ISOBuster. Then rebuild the ISO using VCDEasy or another burning program.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Iso Burning problem.
By whendreamsweep in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2007, 11:24 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
