During the process of encoding certain files, the program creates an .mv2 file that just gets bigger and bigger until it fills up the hard drive.
There is an FAQ question on this, but no answer. I'm guessing I may have a currupt MPG (although the file plays fine in media player!), but if anyone can offer me some guidance here, I'd much appreciate it.
I have the + version, and XP, and normally plenty of hard drive space (about 15gb on this drive, which should be plenty!)
Cheers in advance
ellispaGuest
Hey,
Can you give us some information about the mpeg: size, audio format, video settings.
Greatings,
Yf -
It happens when the mpgs are not "closed" properly. There is nothing I can do about it. Your only option is to reencode the mpg using a mpeg encoder. I have only seen this happen once or twice however.....
ellispaGuest
Cheers for the replies.
It was a broken mpeg. One of the files hadn't completely downloaded (it was about .01 of a meg short of complete, so it would work in media player, but not in this). So I completed the file, and it seems to work okay now.
Cheers again.
Paul
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
